The left control arm is apparently bent, and the wheel alignment does not hold as a result. The mechanic says the bushings are worn out on both sides. Right control arm is apparently not bent, and the replacement is double the price of the left (I checked online) due to scarcity. I am going to replace both, but the question is, are the bushings separate from the control arm, ie,should I keep the old right control arm if it is good, maybe I could sell used and recover some of that doubled price on this scarce item? Or are the bushings integral to it such that it is no good?
Thanks for the input!
