1 - 16 of 16 Posts
1978 300d
i've noticed lately that there is a metallic sounding rattling noise that occurs just before shifting up (i think it's only before the car is warmed up and running for a little) it sounds like the noise is coming from below my shifter (automatic transmission) does this seem like something i should be worrying about? i'll try to get a video/audio clip of it tomorrow. thanks!
· Outstanding Contributor - Always Remembered, RIP
Zotye Auto 1.5T T600 2016
It may be a bad catalitic converter. Does it make this noise whilst the car is in park and rev the engine?
1978 300d
Discussion Starter · #9 ·
it doesn't make the noise when idling, even if the engine is revved..it's just a subtle rattling at high rpms just before it shifts up. are shifter bushings an urgent/expensive fix? is it something i can DIY if my brother is a mechanic and could give me a hand?
All four bushings are only a few dollars, and it's an easy DIY. It's not urgent, just make sure the car engages Park when you put it there.
1978 300d
Discussion Starter · #11 ·
great! thanks for the help. maybe i'll make that a project soon since i have off all week :D
1978 300d
Discussion Starter · #13 ·
I replaced just one, item #11. I did so from under the car.
where did you get the part? i found a tutorial in the w123 forums describing how to do it through the ash tray/center console..i think i'll give that a try.
I searched the epc to find the part number and entered that into Autohausaz.com: Your Parts Search Returned 1 Part(s)
Same with this: Your Parts Search Returned 1 Part(s)
The former, as mentioned, is replaced from under the car, no need to remove anything, just pull the shifter all the way back and inspect. If it's good, then start digging in the console.
1978 300d
Discussion Starter · #15 ·
thanks alot for the help! the sound has kind of stopped since i posted this, but i'm sure it'll return, so i'll take care of it then :surrender:
1 - 16 of 16 Posts
