2006 C180 Manual
Hi All,
Im new here, and glad to be apart of the MB family.
I drive a 2006 C180K Manual, in the last 2 months my car had misfired twice.
The first time i took the car to the shop the engine returned misfire on cylinder 2 and cylinder 4. The misfire disappears when the ignition is switched off and on again. My mechanic reset the fault codes and i was good to go until yesterday:mad:, when the misfire returned. I switched the car off and back on again and the misfire disappeared. The EML remained on. I took the car back to the shop and the engine returend misfire on cylinder 2.
Has anyone experiend this issue.
Please help to what it could be.
Thanks in advance.
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Could be a bad coil - try swapping coils #2 and #4 with, say #1 and #3 to see if the error stays with the coil or the cylinder.
2007 mercedes c230 sport
I know this might be a reach, but was there any resolution to your issues? I'm having the same problem, 3 times including intake camshaft code. And when I cycle the ignition, everything clears up and runs right as rain.
