1 - 14 of 14 Posts
SLK 230
Just recently, when I wash the windscreen with the washer-jets I get a really horrid smell. Smells like someone urinated in my washer bottle. I normally use a nice-smelling screen wash from my local car store. Is there any way to empty the screen-wash tank without just spraying it out? also, what could cause the smell ? I don't believe that screen-wash goes bad. Could there be stale water at the bottom of the tank that is now getting sucked up when I spray ?
SLK 230
The storage bottle is located behind the right front wheel.
Remove the fender well liner and it is right there.
I don't know if there is a drain but you can unmount it and dump it out or loosen a hose at the bottom of the bottle and let it drain out.
SLK 230
Thanx AMPM. Guess to loosen the hose will be the easy option. Maybe I'll flush it out at the same time.
SLK 230
Cheers Rattle !
I figured I'd flush it out while I dump the old fluid, but the tip of sterilising is a good one too. This is turning out to be a major operation, but I'll be glad when the horrid smell goes away.
SLK32, ML430
You can get a handpump from a hardware store. You should be able to get the majority of the fluid out using it.
1999 SLK230/ 2006 Passat/ 1995 Bronco (Prerunner)
I think my battery leaked acid on the top of the washer bottle because it always leaks when I fill it up. When I changed my battery there was a decent amount of corrosion under it. Maybe it is contaminated by acid. I hope not but a thought.
Andy
BenzWorld R170 SLK Host
2002 SLK32 AMG
My guess is that it didn't go bad, but rather a garage filled it up with winter formula. The stuff Mercedes uses from the factory smells like vinegar mixed with some kind of alcohol. Not quite a urine smell, but definitely not pleasant.
SLK 230
Hi SilverSLK
Luckily its not the battery corrosion. I changed the battery just before christmas, and everytinh was clean down there ! thanx for the tip.
SLK 230
It did smell quite "vinegary" to start with Brian, now its getting worse though... think I'm gonna dump it out and put some nice smelly stuff in.
2001 SLK 230
if I was a tech at MB and someone pissed me off I would piss in there tank. lol did you rule out human piss?
SLK 230
Discussion Starter #13
They wouldn't piss in my tank. I'm always nice to them, even get them gifts at christmas....
maybe the wine i got them tasted of piss so they returned it !! [:D]
1 - 14 of 14 Posts
