1 - 20 of 28 Posts
W140 S300DT
Suddenly the rain sensor of my W140 doesn't work anymore.
Anyone has suggestions what could be the reason?
If put in position 1 it keeps whiping. Normaly when the window is clean and not raining it stops automaticly.
Greeting from rainy holland.
Mercedes S500 - W140 && S500 W220.
Here you go Holland buddy...
W140 S300DT
Discussion Starter · #6 ·
Dear Salman108, i know how a rainsensor works. Only mine is not functioning anymore!!
Can somebody tell me what could be the reason.
Electrical problem? Or something else?
Did someone have the same problem?
Is there a fuse for the rainsensor?
Hope somebody has a solution that can solve the problem.
Greetings from holland.
'97 CL600
I would guess that one would have to run a diagnostic to find the problem. I have a fairly new windshield but my system will not engage except manually. Since if rarely rains here in the desert, this is not one of my top priorities.
Anziani
'97 CL600
It is about the diameter of a cigarette and is in the outside glass near the rear view mirror. It is very hard to see. There is a compartment in between the windshield and the rear view mirror that houses the connector. At least on my '97 CL500
Anziani
99" CL500 , 99' CL500, 97' S500, 01' S500, 02’ G500, 09’ G550
I need some assistance on this... My rain sensor works only if I push the entire plastic enclosure closer to the windshield... in other words, if I turn it on it will not work... when I put my hand on the housing for the sensor under the rear view mirror and push it (very slightly) towards the glass, it turns on and works perfectly... any ideas? can I adjust the rain sensor housing?
1 - 20 of 28 Posts
