Rain or Gill a question......
875 Views 2 Replies 3 Participants Last post by  MPM77
Will 98 climate control plug right into a 95 wiring harness? You know the long single unit from the 3 individual units?
And is the "tan" from a 98 the same interior "tan" as a 95?
Thanx again for your group support!
W140 S class, E31 850Ci, XC90 Exec AWD geartronic
These units have been swapped before by other people. Because of this, I assume the connec...
These units have been swapped before by other people. Because of this, I assume the connectors are going to be the same. There are issues relating to the rear window defrost switch because its also on the unit newer type unit. I have not seen the the newer units before so I am not sure how this would work.
The Interior is colour coded. for example, mine is silver (code 7C44) make sure that this code matches your own.
I think Rainmaker will be of more help to you than I. He has had his console turned out and has experience of the connectors and the AC control unit itself
The picture below shows the connectors on the newer type control unit
2001 S500
I think they are the same. However, what makes them look different is that the top part of the dash and steering wheel are color coded starting in 98, whereas, the steering wheel and top part of the dash in model years 92 through 97 where brown in contrast to the tan colored seats.
