Merc ML270 CDI '01 & Merc Vito 108D '99
Hi Guys
So last week i got a flat tyre and didnt get around to changing it until yesterday, ML was sitting up maybe 4/5 days, got back in it yesterday and Radio won't turn on????
We have had extremely bad weather here past week too, snowy and icy conditions and down to minus 7 degrees last night so woul this have something to do with it?? checked fuse and its ok
Hope you can help
Cheers
Mark
02 ML320 06 ML500
There are actually two fuses to check. Fuse #10 and fuse @21.
By the way, what happened to your ESP module from Poland? You should always let the forum know what happens, so we can make proper referrals.
ESP unit didnt fix the problem :crybaby2:
Dont know where to go next
And i just checked that fuse no 10 and thats fine so no joy as of yet
02 ML320 06 ML500
Remove the radio and then remove the connectors from the radio. Then with the eng. running, on connector A check for 12v at red wire #4,,,,,,then check for 12v at pink wire #7.........then check for ground at tan wire *8.
