1 - 19 of 19 Posts
1993 190E 2.6
I'm installing new speakers and cleaning up the wiring to the aftermarket radio that the previous owner made a mess of. Since I am running new speaker wiring directly to the speakers I don't need to sort out the OEM speaker wiring. But there are a couple of wires that I'm not sure of and need help identifying.
This group seems to be the alarm wiring to the OEM radio and I'm assuming that I can leave it unplugged and not worry about it.
I don't know where this plug came from. It has a black/yellow wire. My tempcontrol button lights don't work, maybe this plugs into the upper center console somewhere?
The blue/white wire (the one without the wirenut on it) could be the antenna control wire. Is that correct?
The other wiring with the wirenuts attach I have figured out.
Bill
96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
here ya go suga
Memory (+12v Constant) Red
Ignition (+12v Switched) Black/Yellow
Ground (-) Brown
Illumination Gray/Blue
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Right Front (+) Black/Green
Right Front (-) Black
Left Front (+) Black/Red
Left Front (-) Black
Right Rear (+) Black/Green
Right Rear (-) Black
Left Rear (+) Black/Red
Left Rear (-) Black
89 190E 2.6 x2, 99 SL500 Sport
in the top picture you can ignore those two wires. they have something to do w/ the anti-theft feature on the stock radio.
1993 190E 2.6
Discussion Starter · #5 ·
here ya go suga
Ground (-) Brown
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Left Rear (-) Black
I guess the bottom picture could be the Gray/Blue illumination wire, if that is the case than I haven't found the power antenna wire yet.
Bill
1992 190E | 1997 BMW 328i | 2001 C320 | 2004 C230K | 2007 BMW 335i
There are also 2 wires which are black and yellow striped. Those need to be connected together with your power wire or else your rear defroster and glove box light won't work.
1993 190E 2.6
Discussion Starter · #8 ·
Yes, I traced that out, thanks. Its always good to get confirmation from someone who's been there before. I believe those are the wires in the last photo that have the green slash on them also. I also think the black/yellow wire with the plug in the second photo is the auto mute wire from the cell transmitter to the radio. I will confirm that tonight.
190e 2.6L
There is no power antenna wire. Once you plug the antenna on the head unit and you turn on the radio, it will come out.
1993 190E 2.6
Discussion Starter · #10 ·
I think I found the blue antenna activation wire, it was covered with black tubing and spliced with the power wire to the bass amp in the trunk that runs with the speaker wires. Wow, just like the wiring diagram shows, imagine that :thumbsup: The blue/gray wire in the last photo I'm sure is the illumination wire. I think that raps up all the wiring questions I had, thanks for the help.
Bill
1992 190E 2.6
I've got most of the wirings figured out, except for one part, my vanity mirror, map lights and ashtray as well as the door buzzer doesn't come on
as for the flat plug with the power/memory/illumination/ground, what is the order of the wires?
I have it (looking at the plug pins facing you, left to right)
1 - Ground(brown)
2 - Power(Red)
3 - Illumination (blue/grayish)
4 - Memory (red)
that's correct, no?
on another note, my speaker wires are a different colour being brown/red and grey/brown...
16 Silverado CC LT 4WD, 12 BMW K1600GTL, 11 Infiniti G37, 10 Infiniti G37x
Is your clock working?
Have you checked fuse #13? And not just taking a glance at it, but actually taking it out and looking at it and maybe trying another fuse that is known to be good.
1992 190E 2.6
That's the one, thanks!
Now I feel like an idiot, didnt look far enough into the fuse box and thought fuse #12 was #13 heh, now I just need some help identifying some wires...
No problem.
1991 190e 1997 C280
here ya go suga
Ground (-) Brown
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Left Rear (-) Black
What about the wires to the L&R door speakers?
1993 190E 2.6
Discussion Starter · #18 ·
Those wires are connected somewhere in the rear of the car with the rear speakers. They share the same speaker input wire.
The door speaker wires come from the amplifier that is mounted in the trunk. I just disconnected the power wire to the amp and left the door speakers in. The amp activation wire is the black one that is also tied to the antenna (blue) wire. So when the OEM radio is turned on it raises the antenna and activates the amp.
Bill
1 - 19 of 19 Posts
