Do you mean that it can still be turned on after the key is pulled, or you never see it go off. If the deck is bad, you may want to look at other options than replacing it with a factory unit.
It does turn off when the power is off. But when the ignition is on, it does not shut off when the on/off button is pushed. This is not a major inconvience in that I just turn the volume completly down when I don'twant it. But is there a simple explanation and solution? Thx
Hi Folks, recently purchased an A45, really enjoying the car. Just having one problem with the Blueooth connection. Hope someone could show me what I am missing!
Settings > Activated Bluetooth.
Under Tel, I can see Connect Device as per the instruction manual, but I am unable to select...
Hi all..
My Mercedes E class coupe 2012 W207 rear tail light (on the boot lid) is not working ..
First of all I’ve tested all the fuses in the boot/trunk.. they all have continuity ..
secondly, all the rear lights work when footbrake is applied except the tail light. I have also tested...
My CL500 2001 with command system is acting crazy - the tape flap opens when you start the car and will do this 3 or 4 times when you drive away and beep each time - it will not accept a tape either - has anyone come across this or even better a fix for this? :)
Hello,
I have a 2015 ML350 and recently the Bluetooth link has been cutting in and out when used for phone calls and audio playback - connects to car, then drops back to phone, then 10 seconds later repeats the cycle. Would love some ideas before I take the care to the dealer for a $$$$$ fix...
