Was driving home from the mall the other day, radio playing, and it just turned off, no display, no nothing. dead as a doornail. check all fuses when i got home, under the good, side of dash, and under rear seat, didn't find a single blown fuse. Anyone know what could of caused this, it was working perfectly, then just dead.
Hello Skirrby and welcome to the forum. Please take a moment to complete your user profile, available via the "User CP" link.
I don't know if there is a fuse at the back of your head unit. I would check that. If it appears to be good, check for power at the cable to the radio.
1997 E420 Sport & 2003 E 500 Sport & 2005 Covette C6
Same thing happened to me and after taking the radio out, I noticed a wire from the connector to the radio worked its way a tiny bit loose. (This after buying a new radio). I just pushed the wire in with a pliers and never had the problem again. Check the wire connector for a loose connections.
2001 E320 / S430
I'll listen to Matt on this one. My Becker head unit was dead when I got mine, it has a 10 amp fuse (or was it 20), which is located at the back side of the head unit. I fixed mine one from Autozone. Now it's connected to TomTom playing MP3 and answering phone. :)
Discussion Starter · #5 ·
sweet, ill check both the connection, and the fuse at the back. anyone know how to go about removing the head unit
2001 E320 / S430
You can make removal tool with thin and narrow blade of some sort or use pair of filet knife that fits, but radio removal tool is cheap. I suggest you to buy one.
Step 2
Just press play.
