1999 Mercedes SL500 1987 BMW M5 2006 Jaguar XJR 2009 Ford Expedition
Hello all
Im having a little trouble with my antenna will not come up. The radio powers ona dn everything fine but when the radio gets power then io hear the antenna attemptd to go up but doesnt. I know its getting power but beyond that nothing else.
Any sugesstions oh what issue isw?
SL55, 300SE, GL450, Daytona 955i
first step will be to take the antenna box out, and see why the mast is wedged... it could be a matter of cleaning/lubing the moving parts...
SL500, GLC300
you need to clean and lube the clean the antenna on a regularish basis. they can be high maintenance.
94 SL600, 89 Jag XJS conv, 85 Daimler Princess, 97 993 63 Avanti 16 Lincoln MKZ hybrid 16 Silverado
My personal experience,
If it runs ( the motor ) then the transport gears may be broken or the flexible mast shaft is disconnected.
Get the system removed from the trunk ( lower bolt/ screw below the CD player and top "nut" that is on the fender. ) The electrical and antenna (phone ) connection are part of the entire assembly and easy to disconnect.
Just disengage the plastic snaps of the motor cover, (gently, old plastic can break!!! ) and lift the cover. When I have done this, I see a white nylon gear complex that can be replaced for about $ 20. On three rebuilds it has been one bent mast and three striped gear systems.
Another issue has been the "Off and On" radio HU connector. The harness connections back behind the Head Unit have slipped apart, so that electrical contact is not always connected. I placed a Clarion pop up screen unit that has additional new wires for a very limited space behind the HU, and sometimes the wires have disconnected!
Good luck.
