1987 300E
Anytime I do a search for radio lockouts I keep getting results about radio codes. So I called the dealer and was told my car is too old for radio codes and that I have to bring it in to be reprogrammed (which the dealer conveniently can't do so I'd have to drive to the one farther away) for $60.
Is this a total load? If I have to have them reprogram the radio every time I disconnect the battery I'm just going aftermarket.
W124 Moderator
The dealer you called is just being lazy. Your radio code is identified by the dealer pulling a VMI (vehicle master inquirey) on the car via the vin number. Once you have the code you can disconnect the the battery all you want. The code doesn't change.
Jayare
1987 300E
Called the other dealer and I waited on the phone while the guy looked it up... and yep, no code. Is my car an ugly goose? :(
99-C43, 05-G55K, 71-280SL, 94-E320 CAB
124's up to 1989 with the early Becker Grand Prix radio did not have lock out codes ...
Believe the codes were introduced in 1990 with the Becker 1480.
