hey all so today i was driving my 1999 s320, and the radio flickerd off then back on quckly, everything else is normal then it did it one more time, i noticed when i hit the bright with the light on the radio on the climate control backlight dim but then go back to normal only a tiny but,,, when i got home i pulled out my multimeter i have 12.6 volts at battery when car is off and 13.8 when car is running
any ideas friends?
thanks
Outstanding Contributor Always Remembered RIP
Nothing to do with those voltages they are all just fine.
I would pull the radio forward and check the plugs and fuse on the rear, you can turn it on with it pulled out, tapping the radio may make it go off and on again, this would be a poor soldered connection in the radio
will do,, i thought the voltage had to be around 14 when running i was like oh no there goes the alternator
thanks man
A perfect battery has just over 12.5 volts and a perfect alternator gives out 13.8 volts
