2002 ML320 White; 2017 C300 White.
My radio has the symptom of no sound:
http://www.benzworld.org/forums/w163-m-class/2589593-sad-news-no-sound-2.html
after reading the above post, I’d decided to disassemble it, and replacing OOC8001-02 chip. I could remove the upper cover and DVD player, but I couldn’t remove the bottom cover. There are only 2 screws at the bottom, after I removed the 2 bottom screws, it won't move. How to remove the bottom cover to get access to the board? Thank you.
· R.I.P. Gone but not forgotten
2006 ML500 2002 ML320
You have to remove everything to get to the three screws that are on the top portion of the board.
Take a photo of the upper portion and I will show you the three screws.
43spd, thanks for the instruction; I will take off all screws that I see to remove the cassette and everything else to see the board. I didn’t have the radio with me to take picture now. I think that I know those 3 screws that you are taking about; they are protruding through the bottom cover.
I hope it was easier than this…but not. Thanks again.
