E200 Kompressor 2001
Hi
2001 E200K W210
Middle of last week I got a message on display about battery and alternator problem and car was slow to start but fine after that. I decided this afternoon to clean battery terminals as voltages were all good. I used a memory saver via cigarette lighter when I disconnected battery but for some reason it did not work. I now have no radio code, message came on the display about ABS and BAS and also my electric windows will only go down but not up again .
Took stereo out to see if I could find a code but nothing obvious - normally codes are 4 digits but 5 are showing up on display. It is Audio 10 Model BE3100, Serial No Y2703560.
If anybody can help in any way with these problems it would be much appreciated? I really need to use car tomorrow for an important long trip.
Cheers
MFK
Discussion Starter · #2 ·
In my panic to get help because my windows were all wide open I didnt do any searches :-[
I have solved the BAS ABS problem - fully lock steering wheel each way and it clears it.
Windows now closed - half press button and they will come up and then hold close position for a few seconds. Have to do this on each window individually.
Just realised seat headrests would not adjust either - all you have to do is move seat fully forward and the hold headrest switch in up direction for a few seconds
It is like some sort of synchronisation process after power supply interupt.
Now just the radio - anyone able to help with a code - PLEASE :p
Cheers
MFK
Synchronization
...Just realised seat headrests would not adjust either - all you have to do is move seat fully forward and the hold headrest switch in up direction for a few seconds. It is like some sort of synchronisation process after power supply interupt...Cheers MFK
My headrests will only go down so far, leaving about 1" between them and the top of the backrest. I asked at the dealer and they told me that's as far as they will go. Thanks for the tip and I will try moving the seats all the way forward. I don't understand why these 2 functions are inter-related.
You are correct: depending on who you talk to, you accomplished either the synchronization or re-synchronization process.
Good Luck with the radio code.
My headrest is the same as yours - about an inch from the seat but at least it moves now!!
We both have 2001 E-Class so I guess that's as far down as they will go and both of ours are working properly?
