2006 C230 139k and 2005 C240 4matic 103k
I bought the c240 with an after market radio and missing the amplifier from the trunk. My question is would the pioneer bran name radio work I bought an amplifier for the car's model?
Thank you
If the car did not have the factory Harmon-Kardon or Bose upgrade, then there is no amp in the trunk - the amp is built into the head unit. Since you already have an aftermarket radio, your options are wide open for adding an external amp. Of course you will need to run wiring to the trunk, if that's where you want to install the amp.
