2006 C230 139k and 2005 C240 4matic 103k
I bought the c240 with an after market radio. Many loose wires in the passenger side of the trunk and no sign of any equipment there. The radio does not work. I have checked the fuse and other possibilities. Are the any thing needed to be attached to those loose wires in the trunk?
Thank you
Loose wiring in the trunk likely has nothing to do with the problem. Does the radio power on? If not, check the fuse for the cigarette lighter - #47 on the front SAM (under the hood).
