I searched and was not able to find any diagrams for a 2006 CLK350 W209 model. I need to replace I believe the upper hose as I see a leak from it but not sure how to do this. Assume its not too difficult but just need some guidance.
MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
i think each end just has a locking ring that must be pulled up about a half inch to release it...,,
drain some fluid first from the lower drain fitting
Yep.. you can buy a "pick" tool from the auto store and it helps big time. Definitely drain it first.. lower right hand corner as you are staring at the engine.
There are some decent Youtube videos on replacing the radiator. Not 100% our model, but close enough. I used them to replace the radiator on my 04 CLK 500.
