1 - 8 of 8 Posts
The radiator fan on my V280 refuses to come on. When the van is moving, there's no problem. However, once static in traffic, it very quickly heats up and I have to pull over and let it cool down.
Any ideas?:crybaby2:
v230 ambernite 1997
Could try checking the fuse in the engine bay behind the fan, mine went once (v230) think it was a 20Amp or similar locatted in a little balck box
313 4x4 ,E320 CDI X 4,A160,A170 CDI ,W123,420 SEL,S420 L,420SEC,230,SLK230K, C180 ,C200,C230K, C230K
as before check fuses then check conectors to fan, and possibly fan switch, these vitos corode at the the joints
99 V280 Ambiante
The fan switch is screwed directly into the rad. The bugger is that it is a dealer only part and will cost you 48 quid. I know because I purchased one last week and then found out it was a coroded wiring loom on mine and merc wont take the bit back. Long story short If the switch is the prob I have a brand new boxed genuine merc one you can have for 30 quid if you need one. Just send me a message if you do.
Discussion Starter · #6 ·
Thanks for that. The 2 things wrong with my V280 were the Radiator fan and the collapse of the rear air suspension. The suspension was resting on the bump stops! I have decided to bite the bullet and convert back to conventional springs. The conversion kit, which costs only £135 delivered apparently takes only 30 minutes or so to do. I got terrific advise from a lovely bloke called Jason I believe. Apparently he sold all the good parts from his air suspension and got enough to pay for the springs!! I have ordered the speings from Prestige Auto Parts.
1999 108 Cdi Traveliner, 1999 V220 Cdi, 2003 V220 Cdi
Hello Mate,
Just in case you weren't aware there's a cracking thread on Air Suspension probs on this forum.
The thread's called 'Damn Air Suspension'
I'd hyperlink it for you...if I wuz smart enough! :confused:
Might be worth a look before you finally decide.
Cheers,
Rob
V280
I also had a V280 air suspension problem yesterday (an connector problem to the compressor, which I have now fixed)
Today my biggest worry is that in trying to overcome a coolant dissipating act I have mistaking"ly" added Bars sealer to my expansion reservoir tank and I that see the coolant dissipating act has subsided by that the engine is still overheating. Previous to this I have poured in 3 litres of coolant in the last two weeks.
Was da matta? Ahhhhh
1 - 8 of 8 Posts
