1 - 8 of 8 Posts
1998 ML320 stock 318,112 miles 2000 ML320 stock 250,994 miles 2000 ML 320 270,224 miles parts car
Wanted to share these images for reference
1 photo shows the tiny air bleed hole that is on the thermostat
2nd photo shows the improved "Zebra " clamps for the lower and upper radiator hoses
part number for the improved clamps is 000000-002775 this is for the 98 ML320
C N B
Product Technology Fashion accessory Wire Glass
Auto part Bearing
Discussion Starter · #2 ·
Also I have a question about the radiator hose markings
On the aux water pump hose photo I know the white mark indicated with a red line
is where the grove on the air filter box line up with the hose to retain the hose> But where
does the white line on the end of the hose marked with black line line up with ?
Also the same question is for the upper and lower radiator hoses that have the white mark on
one end of each hose. What do they line up with ?
All 3 of the hoses are of the Valeo Brand
C N B
Brace
Auto part Pipe Exhaust manifold
Discussion Starter · #6 ·
I am doing some PM with hoses and breather cover hoses and I had a leak on the "Y" hose from expansion tank to back of engine . The hoses are probably original and car has 300,000 + miles on it so with hoses being replaced I went ahead and ordered a thermostat
I see where the 2 bottom hoses match up with marks on the water pump housing ( thanks Witek_M ) and assumed there is a mark on the thermostat for the upper hose to match with
C N B
1 - 8 of 8 Posts
