fan control unit?
2000, S500 - 3 years ago my fan was making screeching noise. Not wanting to spend $1200 at the dealer I decided to fix it myself. Think Safety!
To prove that it was the motor – with the car off I connected 12v directly to the motor – screech. I then removed the belt – screech. Yep the motor. I took the motor apart to see about replacing the bearings. I could only replace 1. The other was fixed. I attempted to purchase just a motor, no luck. Had to buy a complete shroud, fan, and motor assembly ($300). I took that motor off the new unit and tested it. Worked fine – quiet. Installed just the motor. This solved the screeching noise problem, but the fan was not running all the time. The car would still heat up to 100+. So, the fan control unit was not working correctly? I don’t remember the exact test, but I check the voltage input (12V) and output The output was not what you would expect. Input was good, but output was 0V. Being variable speed fan, there should be other voltages out (don’t know what). I purchased a new fan control unit, installed and all WAS working fine.
Last week the Coolant – Visit Workshop light came on.
Checked the fan, runs high speed when connected to 12V, runs low when defrost is on. The fan does not run when the car is on and between 80-110F. 80-90F is the normal temp. Outside temps have been about 60, so the car temp does not get to 100 very often (unless in stop and go traffic).
It appears the fan has some other device controlling it if it will run when the defroster is on.
Before I purchase another fan control unit, does anybody know of any other item that might be bad? Temperature sensor? Thanks
