on my 2000 s430 radiator cooling was noise and get stuck because bearing.I buy new fan motor instal and now fan is getting only 3v and run very slow.I check fuses # 33 & 48 , when I pull out fuse 48 out fan is start spinnig on full speed but my AC is not cold I check freon pressure and is only 15psi low.Before fan motor went bad my AC was working good.
Now is my question do I should put more freon in?(maybe high pressure safety valve release freon because high pressure in lines due fan not working) or is just low because my fuse #48 is out?
Is my fan module by air pump bad?or is just temp sensor bad?
Thank you for your help
Zotye Auto 1.5T T600 2016
You have a pressure sensor in the AC system that will trigger the fan to a higher speed and because the pressure is low the fan will not change speeds. Just add freon and all should be OK.
