Moderator
M20
I need to replace my radiator cap. Not sure if there were changes between the early and late model 140 but mine was the all metal black colored one. I have ordered from the stealer and another shop and they both offered the 210 replacement which is the all plastic. tried it anyway and it didnt fit
Anyone with the all-metal cap, can you read the part number on it?
thanks
1992 500SEL
thanks
My car is a 1992 500SEL. Got this kind of cap on.
The part no. is in the pic.
Hope this helps. :cool:
Moderator
M20
thanks DT - I appreciate the pics. But mine is the all-metal kind. If anyone is similar to a 201 and 124 rad cap, mine is similar but all black (i/o silver)
any chance its bec mine is a 300SE?
1998 140.070 CL500, 1966 406.121 U65
First, do you have the M104 (300) or the M119 (500) (its not in you avatar.)?
For early M119;
Êàòàëîã
(so that tank that you have D.T., must have been replaced at some point time.)
The M104;
Êàòàëîã
Both pointing to that the correct part number are;
A1295000006 that replaced by;
A1245000406
The one you should be trying/able to obtain is then A1245000406
like here;
Parts Search :: EuroPartsAmerica
br,
syljua
1992 500SEL
For early M119;
Êàòàëîã
The M104;
Êàòàëîã
A1245000406
like here;
br,
syljua
Oh okay:), thanks for the info.:thumbsup:
Moderator
SL55, 300SE, GL450, Daytona 955i
all early models used metal caps (2 part numbers with 2 different compression rating)
starting with 1994 or 1995, they adopted the plastic cap design, one size fits all, and allowed retrofitting the older models with the new cap.
however, installing the new cap, requires replacing the bottle (over flow tank) and vice versa.
