I have a 1973 450SL that I have spent a significant amount of time (and $$) on trying to get to run smoothly. It is running much better than before but I still have a couple of nasty bugs I want to get ironed out.
The weirdest one has to do with a cold start issue. The car will start just fine but after about 45 seconds of running the idle begins racing in a pulsating manner; approximate RPM: 800->1500->800->1500->800->1500....this repeats until I put it in gear and then drive away. It does not happen again until the next cold start.
Other problems that may (or may not) be related:
- Hot start problem (there is a lot of info here on this problem; I am replacing the auxiliary fan electronics to ensure the compartment runs cool enough and am also replacing the fuel pressure regulator)
- Rougher idle than I would expect (not bad, but not clock-smooth), and the engine runs rough when first applying accelerator when pulling away from a stop (running it leaner appears to have helped this last issue).
