1 - 20 of 34 Posts
Hello folks, searched hi and low to find info on the following wheel design, according to datacard appear to be a factory extra.
R57 LIGHT ALLOY WHEEL 5-SPOKE DESIGN 19" ALL-ROUND
I thought the finish maybe just plastic trims on steel but possibly not, either way the chrome plastic finish is starting to peel quite badly in places - just pondering the best solution (this is only a run about for time being).
Thanks,
Outstanding Contributor
A200 Sports Coupé C169 2006
Are you sure you're talking about B-Class W245?
There was never a 19" factory option, as far as I'm aware.
There's a Brabus 19" running rather skinny 215/35 tyres, but that's it.
Here's an excerpt from the official brochure - largest one is 18" (two actually).
Thanks, those look very similar (Bokhan) second picture down on brochure.
This is the full spec from VIN decoder;
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
221B SIGN COOLANT/REFUELING - ENGLISH
244 SPORTS SEATS, FRONT
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
283B AIRBAGLABLE - ENGLISH
290 WINDOWBAG
330 CD COMPARTMENT
345 RAIN SENSOR
391U HORIZONBLUE - METALLIC PAINT
410 MANUAL TRANSMISSION 5-SPEED
441 VITAL SENSOR ON STEERING WHEEL
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
477 TIRE PRESSURE LOSS WARNER
486 SPORTS SUSPENSION
523 RADIO AUDIO 20
537L GREAT BRITAIN AND NORTHERN IRELAND
551 BASIC ANTITHEFT ALARM SYSTEM (ATA)
570 FOLDING ARMREST, FRONT
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
580 AIR CONDITIONER
584 ELECTRIC WINDOW REGULATOR
593 ALL-ROUND WD-GREEN GLASS,HEATED REAR WINDOW-ESG,BF
5XXL EUROPE
613 HEADLAMP LEFT-HAND TRAFFIC
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
690 EMERGENCY SPARE TIRE (MINI SPARE)
723 TRUNK COVERING
739 TRIM PIECES - ALUMINUM
750A LEATHER COMBINATION
751A LEATHER COMBINATION - BLACK/ANTHRACITE
806 YEAR OF MODIFICATION
882 SENSOR SYSTEM AND ANTITHEFT ALARM SYSTEM
885 HIGHTEN THEFT PROTECTION
952 SPORTS PACKAGE
983 COC PAPER EURO 4 TECHNOLOGY W/O REG. CERT. PART II
989 IDENTIFICATION LABEL UNDER WINDSHIELD
M17 DISPLACEMENT 1.7 LITER
M266 R4-GASOLINE ENGINE M266
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
U37 FOGLAMP
U58 HEADPHONES F. REAR SEAT ENTERT. SYST. (AMOUNT 2)
2006 B 200 .....& Audi A6..
Never seen that kind of damage on a wheel before. Not an easy repair..
Place these pics and any questions in this forum and see what help you get.
...Good luck..!!..
Never seen or heard of a 19" on a W245 (or W169 ... hmm ...)
It's the last one on page 4 (or 11 in the actual brochure), but it shows it as 17" ...
Finish is a chrome-plated type, that explains the peeling.
If these are indeed 19" you could swap them for re-furbished 17" or 18" and probably cover a set of new tyres too ;)
Check firstaidwheels - they did mine over 3 years ago and they still look pretty good:
Is it me, or does my 18" wheel look bigger?
The brake disc (aka rotor) is the same size.
Could it (the 19" bit) be an incorrectly resolved code from a VIN decoder?
Can you take a pic of the tyre markings?
I'm intrigued ;)
Discussion Starter #12
I just tried to take a few pics of tyre size, its dark so missed the lettering as quite small.
The gap between tyre and wheel arch is very small, not enough room to clean the arch (yours looks more spacious) - the sport package as listed, maybe this type/size wheel were included as an option?
Very interesting!
I too have sport suspension (952) on 18" AMG wheels, but mine is an A-Class coupé A200, plus I now fitted taller springs (village life is lovely, but roads are atrocious). My winter alloys are actually 16" - car looks like an ATV on them ... I actually like it, to my surprise.
Discussion Starter #14
I could be wrong but these look and feel like trims,i.e they sit on top of actual wheel - underneath the chrome it's plastic?.
My last car was a 1996 S124 which was old skool, this takes a bit of getting used to (can't believe you have to take engine out to swap the clutch o_O )
If you think 245's engine bay is tight, you should see 169: everything is the same, other than the body shell, which is smaller! I'm surprised they didn't make it engine out job to change oil!
Tried to fit top quality LED bulbs for full beam yesterday (done dipped ones almost two years ago), gave up as couldn't be bothered removing washer bottle or growing 10" fingers. Fitted OSRAM Cool Blue BOOST 80W instead ... not the same, but will do till summertime.
No, it's chrome plating on a light alloy (which does look like plastic without any coating on).
Discussion Starter #17
Thanks, MB labour on a clutch swap has to be close to market value for actual vehicle -
'Noisy thrust bearing'
'Sorry Sir, your car is a write off'
:D
There are a few trusted indies - whereabouts are you?
I do use MB for Service Care Plan - mostly because it makes financial sense, when large items are coming due in the near future, e.g. ATF, sparks, fuel filter, etc, but for everything else - either DIY (brake pads recently for the first time ever! LOL) or indie.
Discussion Starter #19
I tend to look out for other jobs while doing another, for example oil change scoping out where the gearbox drain plugs are along with clutch housing. Hopefully clutch should be okay for a while yet although gearbox oil will be done once weather warms up a bit.
Better photos of wheels, tbh its only really one that looks ropey - its probably not worth a proper wheel refurb, just needs tidying up - spent some time with eight hole alloys rubbing down and prepping before using several layers of acrylic paint, came out really well and lasted better than a set professionally done.
Here's my old barge , not a great picture of wheels but they were something like 5/6 years old.
2620642
1 - 20 of 34 Posts
