2007 R320, 1992 500 SEL
I have a 2007 R320 with an engine oil leak. The oil appears to be coming out of the weep hole on the drivers side of engine block. The air intake gasket and PCV valve are in good shape. Any ideas ?
2000 E430 4Matic, 2007 R320 CDI, 2012 E63 P30, 2013 SLK250
it's hard to see leaks without exposing all possible locations where leaks are likely to happen. I would suggest removing the partition cover near the firewall and then remove the engine cover. You will be able to see much more...
Did you have recent work done? ie. air filter or fuel filter replaced?
-Robert
