For those who haven't seen it, a recall letter was just sent out to owners of 2006-2008 ML, GL, R, and E classes with diesel engines. The problem is a crankshaft position sensor that can suddenly fail, leaving you stranded, or even worse, in the middle of an intersection turning into oncoming traffic (!)
Yep Just got the letter. Scary!!!!!!
Got mine last night.
Reminded me of all the PowerStroke diesels I've had. Everyone one of them had a spare CPS & wrench in the glovebox. Never knew when they would fail, but when they do, the engine is Dead Right There!
Interesting! I have also heard of them failing on gasoline engines, where they can also cause sudden failure. Yet I wonder if because a diesel engine is a much harsher unit (temperatures and vibrations higher than a gasoline engine), that it would result in more problems with crankshaft-position sensors -- unless of course they are engineered to be extra robust. This would never been a problem in the old days of mechanical fuel injection systems, only with modern systems with sensors such as these.
I guess I also wonder if these high-tech diesels will last any where near what "old school" diesels were legendary for ...
Sure, modern diesels can actually last longer than the old school diesels, mechanically. I don't know why Ford/International/Navistar had so many CPS failures being they are simple magnetic/hall effect devices. The newer 6.0 & 6.4 PowerStrokes have fewer failures. Usually with Ford, it is bean-counter related.
