1 - 1 of 1 Posts
Hi Guy's i'm a newbie to this site and looking for help!!!!! i have a 2004 SL350 with an intermittent fault on the rear light's, when braking both rear fog light's flash like strobe light's in a very erratic way almost like a bad earth when the fog is switched normally only the o/s illuminates as it should, also when it is in "play up mode" the LED tail light's flicker very slightly, so far i have cleaned all the earth's in the boot/trunk, checked the rear SAM circuit board for green corrosion and hard wired the canbus (brown wire multiplugs) under driver's/passengers front floor, had communication problem's with Star last week and was told to hard wire the corroded terminals before they could try again, just wondered if any of you Guy's had ever come across this fault???? Many Thanks Simon..
1 - 1 of 1 Posts
