This can be frustrating and I have not seen it properly addressed on other posts. First, remove the carpet and rear trim piece from the trunk. The trim piece is the one held by three clamps with straps. Lift the black plastic tire compartment cover and hook onto its retainer hole on the backside of the trunk lid. Snap the jack out of its holder and remove.
Here comes the “trick.” Stand facing towards the right of the vehicle and grab the wheel with the left hand at the 12 o’clock position of the wheel and with the right hand at the 6 o’clock position (opposite hands if you are left handed, you want your strongest arm to be at the 6 o’clock position). Simultaneously tilt the rear of the tire towards the 45 degree position while lifting the 6 o’clock hand upwards and outwards, pulling the tire out in line with the centerline of the vehicle. You can see why you need to do it this way from the picture of the tire compartment with the molded plastic cover for the top pump. Trying to go left or right with the tire is futile, it has to be removed straight up and out in line with the centerline of the car.
After using the jack, it is important to remember to drive the engaging pin all the way to the bottom and inserting back in after the tire is in place.
