Banned
Y2K SL500 Silver
Banned
Y2K SL500 Silver
Discussion Starter #2
See the attached PDF's and how to reset the Flexible Service System counter on 1998 and newer MB and read Flexible Service System - FSS started in MY98
If you have a problem with the reset and your car happens to end up reading -200 with no odometer readings it's not necessary that you take your car to a MB dealer for an SDS reset.
Try pulling the fuses, located under the hood, to the dash cluster and wait a couple of minutes. Reinstall the fuses and turn your ignition key to position 2 and note that you have your odometer readings again.
