The posts below are organized by the year of the car.
First Group>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Function Description of Roadster Soft Top and RST Troubleshooting PDF's
The soft top control system is surprisingly simple. The controller executes a step-by-step sequence of motions as illustrated by the document
96 SL and later cars require a M-B STAR Diagnostic System scan tool in order to check for DTC's and reset controller
99 SL codes were reset for $40.00 at the Dealer because Soft top was stuck down and roll bar stuck up!
***Remote Soft Top controller p/n's and repair/rebuild facilities
BBA-Reman.com UK rebuilds your control module for $375 plus SH and they give you a warranty.
R129 remanufactured soft top control modules for $375-$715+tax+ship vs. $1360.00 at the Dealer
All Power Top Control Modules are $595 and come with a two year warranty.
Attached is a picture of the circuits from an early version of the control module
SL soft top control unit location
00 SL soft top control unit location
To remove the hard top you have to operate the switch within 10 seconds of turning the key on and the windows have to be down
00 SL soft top stuck in compartment
00 SL check the state of all of the limit switch inputs to the controller, controller holds information up to one hour
97 SL windows won't synchronize due to a defect either in both window motor units or the soft top controller
97 SL BE CAREFULL WHEN LEAVING YOUR CAR AT A BODY SHOP-DO NOT LET THEM JUMP OR CHARGE YOUR CAR-HAVE THEM CALL YOU FOR THE CORRECT PROCEDURE
97 SL soft top controller probably is not getting the signal from the left door switch
97 SL discharging when the car is off
97 SL red button stays flashing
97 SL Central Locking not working
1997 S84/4, "reed magnetic contact switch" sits in the windshield top cover
*97 SL battery lost charge>then recharge>now red soft top and rollbar light permantely>means diagnostic codes need to be reset by Indy or Dealer
1996 Fixing the bow extension micro switch
*96 SL and later with a fault in your soft top controller which can only be reset with and advanced diagnostic tool
*96 SL and newer cars need a scan tool to reset codes, go to Indy or Dealer and ask how much to reset the soft top codes
*96 SL go to the dealer or a mechanic who has the proper tool and have them read and clear codes in the soft top controller
*96 SL soft top controller controls the roll bar on '96 and newer cars
How to reset the roll bar after it has been deployed.
How to adjust and/or reinstall the roll bar sensors
MY 93 and newer picture of 38 pin plug under the hood/bonnet of a RHD car
Second Group>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
95 SL windows must also be "synchronized", as explained in the owners manual
95 SL controller is not receiving the proper inputs telling it that the top is completely closed/open
94-95 SL There are just 10 diagnostic codes instead of 29
*R129 diagnostics through model-year 1995 and codes
*90-11/94 SL how to read diagnostic codes by Bob Terry
*SL Soft Top Controller Reset and Roll Bar Codes and Reset Procedure
94 SL soft top will not complete an opening or closing operation unless both windows are lowered
?? SL roof stuck under the bonnet!
?? SL diagnostic socket in the passenger footwell. You only use this to put the top controller in a special diagnostic mode which evaluates the limit switches
94 SL top closing operation stops because the passenger window has not lowered
Third Group>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
93 SL soft top won't open/retract
93 SL Convertible top cannot complete its cycle
93 SL has a problem when opening soft top
92 SL Convertible top
You don't synch the windows on an early SL
92 SL roll bar and soft top stopped while going down
92 SL and I don't know what is wrong with the soft top
92 SL limit switch located in the bottom of the door
92 SL ASR light always on and the Rollbar is coming up by it self when im driving i cannot release my hardtop automaticly
*91 SL method of clearing and reading the soft top codes
91 SL I wouldn't do anything without reading codes for the top controller first.
91 SL are you activating the release switch within 10 seconds of switching the ignition to ON
91 SL indicator lamp will not stop blinking along with the audible warning
91 SL how to verify that all inputs from the various limit switches are working properly
91 SL cleared ALL codes AGAIN, disconnected the controller and cleaned all pins and sockets with electrical spray
*91 SL Reading codes is simple and all you need is a wire or a paper clip to use as a jumper
90-91 SL soft top problem
90 SL Front top latches don't close
90 SL everything is latched properly but the switch is still lit, then one of the microswitches isn't signaling the controller
90 SL soft top problems
R129 soft top 'Hydraulic System' ultimate thread
