1 - 20 of 24 Posts
1998 Mercedes S420
If you don't see what your looking for on here just ask me. Pulled from a working 1976 450 SLC. Interior is tan. Sorry No Trans Parts as the transmission was going out. Unless you want the whole trans for rebuild. Parting out the top of the engine (engine runs and drives very good i would consider selling the whole unit, but only local and you would have to pull it.) Pickup only on heavy or very bulky items.
All these parts are in working order, in good or better condition.
Battery - $20
Ignition Control Module - $100
Smog Pump - $30
Becker Mexico Radio / cassette - $75
Becker Radio Wiring Harness Plugs - $30
RH Mirror - $50
LH Mirror - $50
Front Headlights (whole assembly) Set - $150
Rear Tailights Left + Right (Whole Assembly) - $150
Chrome Grille - $75
Front Bumper - $75
Rear Bumper - $75
Rear Bumper Passenger Rubber - $25
Foglights Pair - $50
Fuel Distributor - $150
Fuel Injectors - $20 each
Fuel Pump Relay - $30
Door Check stop L&R - $50
Radiator Resevoir Tank - $50
Radiator - $175
R Power Window Switch - $15
L Power Window Switch - $15
Shift Console Cover (black) - $25
Drivers Window Motor - $40
Passenger Window Motor - $40
Bosch Alternator - $40
Windshield Wiper Motor - $20
Windhsheild Wipers + Blades - $20
Hazzard Flasher Switch - $15
Sunvisors (pair) - $50
Turn Signal Wiper, Cruise Switch - $75
Ash Tray - $30
Head Rests Pair - $50
Passenger + Drivers Seat Back - $75
Rear Bench Seat with Arm Rest - $50
AC Compressor - $150
HVAC - Receiver Drier/Accumulator - $10
Heater Blower Motor - $100
Valve Covers Pair - $50
Aluminum Hood (No Dents) - $100
Rear Defroster Relay - $40
Fuel Gas Tank - $300
Spare Tire Cover $50
Power Antenna Switch - $15
Sunroof Switch - $15
Rear Defrost Switch - $15
Fuse Panel - $30
Drivers Side Front Window - $50
Passenger Side Front Window - $50
Drivers Side Rear Window - $50
Passenger Side Rear Window - $50
Drivers Side Louvre - $50
Passenger Side Louvre - $50
Louvre Window Chrome Trim (pair) - $50
Inner Door Jamb Window Chrome Plate (Pair) - $20
Drivers Front Side Door Panel - $50
Passenger Front Side Door Panel - $50
Drivers Rear Side Door Panel - $50
Passenger Rear Side Door Panel - $50
450 SLC Floor Mats (Front Pair) - $50
Cruise Control Amplifier - $10
Air Cleaner - $50
Bosch Ignition Coil - $25
Glove Box Door - $50
AC Control Panel - $50
Door Sill Floor Trim Plastic (Pair) - $25
Inner Door Carpet Chrome Floor Trim (Pair) - $20
Inside Door Handle (Pair) - $35
Outside Chrome Door Handles (Pair) w/ key - $75
Distributor w/ cap rotor - $80
Drivers Side Door - $100
Passenger Side Door - $100
Aluminum Hood w/ new emblem - $100
Trunk Lid w/ trim- $50
Ignition / Lights Alarm Buzzer Module - $20
Front Right Fender Trim - $20
Front Left Fender Trim - $20
Rear Right Quarter Trim - $20
Rear Left Quarter Trim - $20
Front Right Brake Caliper - $30
Front Left Brake Caliper - $30
1998 Mercedes S420
1995 325IC and 1986 560SL
Battery - $20
Smog Pump - $30
RH Mirror - $50
LH Mirror - $50
Chrome Grille - $75
Front Bumper - $75
Rear Bumper - $75
Radiator - $175
Ash Tray - $30
Fuse Panel - $30
Air Cleaner - $50
Where are you located?
560SL
Do you still have the driver's side window?
I need the bracket from the bottom front of the window but can buy the entire window as well.
Brent
1973 450 SL
Hi I would like to replace my console with a better one, didn't see it listed. If you have one could you send me a picture?
1984 280 SL euro
can you send me some pictures of the hood!? thanks
my email is [email protected]
i am located in the bay area =]
thanks again
bumper and more
lilytek,
I'm definitely interested in the front bumper. Also the R power window switch. I would be interested in a right front fender if you have it. All of these for a '73 450sl. Let me know. Thanks.
-Steve
1999 Porsche 911 / 2013 ML350 / 2006 Mini Cooper S
Still have the ash tray? I need the chrome piece from the top of the unit for my 560SL, but I'd buy the whole thing.
1979 450 SLC
Cancel-Cancel-Cancel 12/22/2009
Hello,
I am looking for the following parts for a 1979 450 SLC.
Passenger side window w/frame
Passenger side regulator w/ stops and bolts
Cruise control amplifier
And not sure what this part is called but it is what caused the window to self destruct. It is kind of a block that slides on the front window track. It was laying in the bottom of the door so I am unclear as to whether it attaches to the window frame or the regulator scissors. I can get a pic if you think you have this part.
Let me know thanks.
My zip is 63084 as far as shipping goes.
email: [email protected]
1974 450SL @ 208K, 2000 C280 @ 66K
Battery - $20
Smog Pump - $30
RH Mirror - $50
LH Mirror - $50
Chrome Grille - $75
Front Bumper - $75
Rear Bumper - $75
Radiator - $175
Ash Tray - $30
Fuse Panel - $30
Air Cleaner - $50
Hi there! I'm very interested in the air cleaner and these parts pictured below (i'm embarrassed cuz I don't quite know the part name or number). I have red lines pointing to the said parts. Mine are rusted kind of like the ones shown here and would like to find some non-rusted parts if possible :).
Let me know?
Thanks!
E60RS Renntech, E500, 300D, 300CE 5 Speed, 300TE 5 speed, 190D 5 speed, 82 300TD, 109 Rover
How about drivers side camshaft?
'84 280sl 5 speed
Guys, this thread is a year old. Has anyone sent him a PM to see if the car/parts are still available?
1 - 20 of 24 Posts
