1 - 12 of 12 Posts
Hi everyone,
I'm looking for a set of belt buckles and receivers only (pics attached, came as whole untis 1078603586 left front and 1078603686 right front) as they're discontinued from MB. No need for belts or spooler as I'll put them on new belts. Please PM if you can help or know of a donor car, right now there's none in the UK or Ireland available.
2609614
Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Shipping from the US should not be too bad if a flat rate box or maybe padded flat rate envelopes an be used.
Is there retractor wheel required too? Or do you just want the buckle (male and female parts)?
Bolts or any other hardware required?
EBay international shipping is easy. I could put a listing up on eBay for you if you want.
Fonzi, thank you! No need for ebay, I trust you, and shipping would be to North Carolina postal 27707.
Assuming the original belt is 47mm then all I need is the male and female connectors plus the bracket thats on top of the pillar - I can then transfer the three elements to the new belt, pic attached.
Do you happen to have any pics? Sorry, I'm a bit
2609645
excited like a kid in a candy store 馃槄
I have a lot of stuff, and can鈥檛 go get pics of everything. Please post pics of exactly what you want. Circle the parts you need in the pics, and I can go see what鈥檚 in my garage attic or parts cars.
Sound, apologies for confusion Fonzi. All I want are the male and female connectors (pieces in red) and if by any chance you have the bracket for the top of the B pillar (piece in yellow) I'd take it too. The critical consideration here is if the original belt is 47mm / 1.85inch or less in width so that the connectors can slide over to the new belt.
I never fully understood the parts you wanted. I only see one part in Red, and assume the pic in hello wan shows a non-MB part. Here are three pics I have, and parts I could imagine providing:
Apologies for confusion Mike, I now see the pic where I outlined the pieces needed didn't upload with the post - my bad! Attaching it below - this is the non MB set and so I'm looking for period correct MB equivalents of male and female connector (in red) and pillar B bracket (in yellow). Is this helpful?
2610199
Lastly, the pics in my first post shows the exact MB connectors I'm after 馃槉
Yes Mike, they're for my 1979 450SL. Same for speaker clips. 馃榿
I will see if I can get to Jason鈥檚 today because I do not have the correct parts for the 79 450sl as far as I can see right now...
These are my 79 450sl...
And this for some reason a 鈥渞epa鈥 belt is laying in the car, I can鈥檛 figure out why or where it came from...
So I think I know what I鈥檓 looking for right now, but don鈥檛 know if I will be able to get it out today with many other things going on.
Discussion Starter #12
Thanks Mike, I really appreciate you digging into this - per our discussion offline let's see if Jason will come through with the belts.
1 - 12 of 12 Posts
