I have a 1985 Euro Model 500sl that has been having some issues. I replaced the fuel distributor about two months ago and an idle air control valve in the last week. When the car is cold it starts up and drives fine for about 5 or less minutes. After a few stops, and the car returns to idle, the idle drops below 500. Often times it even drops as low as 100-200 rpms. My vacuum gage is usually pined to the left at idle and doesn't seem to move. I tried replacing the idle control unit as it appeared that it wasn't operating the idle control valve. Put a new ICU in and nothing. Returned it and got a idle control valve. Still nothing. Reading with a volt meter how is the idle control valve suppose to act. Should I feel/hear the valve turn on and operate with the key turned all the way over but not running? What else can I check on the car to try and determine this problem? The car seems to be running rich as well. may or may not be related to this problem as it has been running slightly rich for a few months. Any help is MUCH appreciated as I have been trying to get this car out of my garage and into storage but very inconvenient to drive as I have to keep my foot on the gas at all times in order to keep it above 500 rpms. If someone is able to help me get my car running well again I would be more than happy to compensate them for their time.
Thanks so much in advance guys
Andrew
Andrew
