1982 380SL
The cabin air sensor on my 82 380SL is not working. I have tested with a multimeter and there is no measurable resistance. Unfortunately part # 1238300572 is no longer available. When I plugged in the temp sensor from the heater box, I started to get blower motor function. The holder is fine so I was hoping to substitute a different thermistor, but need help with the specs of the original. Any other ideas would be greatly appreciated.
2007 ML320CDI, 1959 220SE, 1971 280SL, 1982 380SL
It might be better to look for a used sensor. All the mercedes with your same verison of climate control use the same sensor. That includes many 82 to 89 models, 126 chassis, (380se, sel, 560se, as well as the 123 chassis, 300D
