1 - 20 of 44 Posts
Edit: 1/20/2020. Due to the site downgrade last year some of the links may be broken or pictures missing. Graham and member andya have put together the information off Benzworld Fuse Compendium – 107 Resources
Change your fuses! Originals are aluminum and they tend to corrode and cause bad connections. Brass or copper tipped fuses are available from many sources.
Many of us have been frustrated looking for a Fuse Layout chart for our 107s. There are some scattered through the forum. This is an attempt to put them all in one place and to gather more from our members.
The fuse layout cards have part numbers of the form 107 545 xx 00. Some may still be available from the Classic Centre.
Pictures of each card will follow in posts below. You can jump to post for your car by clicking on the links below.
If anyone has fuse card pics of the missing cars, please post them - Probably best in the other thread titled FUSE CHART - FUSE CHART
1971/2 early 350SL Card# 1075450000 In German Info from Chiltons added.
1973 450SL and later 1972350/450SLs Card# 1075450200 Info from Chiltons added.
1974 450SL Card# 1075450400
1975 450SL Card# 1075451100
1975 350SL (EURO model) Card# 107545xx00
1975 280SL
1976 450SL Card# 1075451300
1977 450SL Card# 1075451500 Could also be late 76?
1978 450SL Card# 1075451700
1980 450SL Card# 107545xx00
1980-85 500SL Card # 1075452200
1980 500SL
1981 280SL Card# 107545xx00
1982 380SL Card# 1075452100
1983 380SL Card# 1075452300
1983 380SL RHD
1983 380SL RHD
198?-1985 380SL (From WEB)
1986- 560SL (From Peachparts)
1987 560SL Card# 1075453100
1988 560SL Card# 1075453100
There are similar numbers for the marker strips that fit under the fuses. Not to be addressed here, but numbers also have format 107545xx00. Perhaps they were supplied as matched sets?
Discussion Starter #2 (Edited)
Submitted by: Peter 107
and another Translation by Engr693"]
From Swedish site (for 1972 350SL):
1. Automatic antenna
2. Parking, boot (trunk) light, glove box light , entrance lights, hazard warning lights
3. Radio
4. Passing light
5. Wind shield wiper, wind shield washer pump, Horn, cigar lighter
6. Empty
7. Blower motor
8. Kombi-instrument, turn signal, backup light
9. Electrically operated fan, air conditioning
10. Stop lamp, starter relay
11. Rear window heater
12. Automatic transmission
13. Parking light right, tail light right, license plate light, dash board lightning
14. Main relay, fuel pump relay
15. Fog light
16. Parking light left, tail light left
17. Head light high beam right, head light high beam indicator
18. Head light high beam left
19. Low beam right
20. Low beam left
This is from Chiltons. Not model year specific so may or may not be useful.
1973 450SL and later 1972 350/450SLs Card# 1075450200
Seems that the later 1972 350/450SL is same as 1973 model.
This one from Cush
and this one from Cook
Fuse strips from my 1972 350SL 4.5 (same as 73 except for Fuse#20.)
The 350SL section in Chiltons seems close to that for 73 450SL. Not model year specific so may or may not be useful.
Not sure where this came from:
Submitted by Goldendragon
1976 450SL Card# 1075451300 and Card# 1075451500
Found on web
NOTE: Some later 1976's may have card# 1075451500 - see 1977.
Discussion Starter #10 (Edited)
1980-85 500SL Card# Card # 1075452200
Found on web (needs verification)
1 - 20 of 44 Posts
