1 - 16 of 16 Posts
U1450L DOKA
A nice look at a RW-1 based on the UHN. A large winch on the front, instead of the underslung Werner in the
rear. The rear box looks a little wider, to my eye, and the sides are vertical, eliminating the taper towards the center of the previous versions.
Tire Wheel Sky Vehicle Motor vehicle
Wheel Sky Tire Vehicle Cloud
Plant Cloud Tire Vehicle Vehicle registration plate
Wheel Tire Vehicle Plant Car
Tire Wheel Cloud Vehicle Automotive parking light
Wheel Tire Automotive parking light Vehicle Plant
Cloud Sky Vehicle Tire Wheel
Automotive tire Vehicle Gas Engineering Wheel
Wood Building sets Toy block Urban design Plastic
White Light Product Yellow Line
U1450L DOKA
Discussion Starter · #6 ·
P.6
I'm pretty sure I have posted this second truck up previously, but I could not find it via searching, so I figured it would fit in with No.18 as its sister ship. Beautiful Equipment. That Jack....
Road surface Asphalt Tar Flooring Rectangle
Automotive tire Engineering Gas Electrical wiring Machine
Light Automotive engine gasket Rectangle Automotive lighting Gas
Rim Gas Circle Auto part Cylinder
Gas Plant Asphalt Tree Machine
Sky Asphalt Tree Automotive tire Gas
Water Gas Machine Auto part Metal
Automotive tire Black Motor vehicle Automotive design Font
Motor vehicle Automotive design Hood Automotive exterior Red
Motor vehicle Automotive tire Vehicle Tire Automotive exterior
1250v
The tools on that truck are as impressive as the truck itself! I need one of those for a mechanics truck! Haha
U1450L DOKA
Discussion Starter · #15 ·
Here is a larger unit from the same fire Department, based on a Mercedes Atego. This one is loaded up with tools, but it is also equipped with a tank, a pump and hoses.
Vehicle Ecoregion Wheel Sky Motor vehicle
Product Tool Office supplies Line Material property
Motor vehicle Electrical wiring Firefighter Gas Machine
Tire Vehicle Motor vehicle Wheel Automotive design
Wheel Tire Motor vehicle Vehicle Automotive tire
Motor vehicle Electrical wiring Vehicle Red Automotive design
Tire Vehicle Wheel Motor vehicle Automotive lighting
Shelving Audio equipment Gas Electronic device Shelf
Motor vehicle Tire Automotive tire Automotive design Mode of transport
Motor vehicle Purple Automotive design Mode of transport Automotive tire
'76 1300L,HE351CW,H15P Winches,Konis,Hydraulics,All Gears,10mm Plungers,Aftercooler,Lots of Littles
These are so well kitted out.
The chainsaw selections, for example, are top notch.
C.
1 - 16 of 16 Posts
