My Two Left Feet
I wanted to clean the sun roof and wanted to know of lining the grooves with WD40 will help or hurt. Thanks in advance for your responce. BTW, this forum has taken up all my MYSPACE time......LOL...even if I didnt own an MB I would still be part of this forum realy great just as a learnig forum.
1998 E320 Wagon
Never use WD40 on any car you care about
Wd40 should not be used on your car. Your sunroof needs no lube what so ever. If your trying to clean the seals you can use a sof tooth brush mild soap and warm water, or just buy new ones. the rail system does not require lube it glides on nylon bushings or glides.
My Two Left Feet
thank you
