S320W
If your car is parked outside, the engine is dead cold and the outside temp is below 20 degrees, do you guys start the engine and let it run before moving the car. I usually keep it running till it reaches the first quarter after the 40 mark.
Is this good practice or should i just start moving it?
Any suggestions on this would be great.
///S320
CLK430
Although some may disagree with the purposes of letting it sit in idle, I let mine sit in ...
Although some may disagree with the purposes of letting it sit in idle, I let mine sit in idle to let the oil reach its designated parts.
