1977 450SL
I took my Auxiliary Air Valve off today and cleaned the inside with break cleaner and compressed air, my Question is after I boiled some water and put the copper end in the cup, the valve closed all but about a 1/16 of an inch. Does anyone know if this is correct, or should the valve close completely?
I believe the valve should shut completely. But at what temperature?
On the earlier D-Jets I have read that it should be 100% closed at 140F and in another reference at 150F. At max operating temperare, coolant is at about 185F on D-jet, so AAV is fully closed. Operating temperature on K-jet is higher, so perhaps the 100% closed temp is also higher? Maybe someone has a reference. But as a wild guess, it should be closed well below 212F.
Some say that AAV is always slightly open because of a step cut in the piston, but my guess is that is just for better flow and/or noise control.
To check if AAV is closing, pinch the hose off when engine is fully warmed up and see if that affects engine speed. It should not.
1977 450SL
Thank-you.
