1 - 12 of 12 Posts
99 ML430
Replacing factory halogens with Bi-X's today and I know I have to up my fuse amperage to 20amps but after lookin at the fuse box and seein all sorts of headlamp fuses which ones do I actually pull to replace with 20amp's?... do I replace both 7.5amp fuses that are beside one another?... any help would be appreciated...cheers guys... have a great long weekend [:D]
99 ML430
Discussion Starter #2
No worries guys... got it figured out... Bi-X's RULE... can't believe the difference and the bulbs are not even worked in yet... thanks for twistin my arm Drew.. haha
99 ML430
replace both 7.5 amp fuses with 20 amp fuses. I forgot what location they were in but second row to the right hand side (drivers side) U should see two 7.5amp fuses... those are the ones I replaced... and all is good thus far...
2020 MB GLE 450 4MATIC, 2015 BMW M4
I didn't replace my fuses ('98) and they've worked fine for almost 2 years.
Member
'00 ML320 Elegance
Greg...
GregW / Oregon - 3/25/2005 8:11 AM
Wow you're lucky then...either that or it's because you have a '98. I do know that we've had many reports of blown fuses for '99 MLs; even Hella says that a fuse bump is required, LOL.
RE: Greg...
Drew - 3/25/2005 5:05 PM
My ML came with the bi-xenons from the factory with 7.5amp fuses; as bi-xenons use less power (35W) than halogen why would you increase the fuse size?
Particularly as GregW found his worked OK for almost 2 years.
Member
'00 ML320 Elegance
Marcel the reason is that you have a 2000+ ML. The pre-00 ones are not configured exactly the same.
OK and thanks, although I am surprised.
I have recently replaced my driving lamp bulbs (H7) and saw that the wiring is quite thin which persuaded me not to try the 80W H7's I was initially tempted to buy.
Perhaps someone should check the 20A fuse advice as I don't think the wiring, at least inside the headlamp unit, is up to blowing 20A fuses with any certainty and you maybe removing a level of protection by upping the fuses from 7.5A to 20A.
Member
'00 ML320 Elegance
marcelc - 3/25/2005 12:46 PM
It's not the wiring that is the issue. It's that the entire Xenon headlamp unit initially requires more power on startup due to the high voltages involved in the ballast/ignitors. This initial spike can cause the lower amperage fuse to blow on the older MLs, due to the different electronics configuration (e.g. only one fuse box, etc).
Actually I was a bit weary as well, and only ran one 80 watt H7 bulb in my high beams to test out this configuration; I use my high beams quite a lot due to the unlit stretches of roads that I travel on daily in the evening, when returning home from work. After 1 month of testing, I was convinced that there were no issues and I've been running 80 watt high beam halogens for almost a year now!
Drew - 3/26/2005 6:33 AM
Thanks, that is nice to know, I may give in to temptation when I next replace them.
Member
'00 ML320 Elegance
marcelc - 3/26/2005 8:59 AM
I wouldn't necessarily run them in the low beams as they would be constantly on, but for high beams I have personally had no issues. I'll also say that combined with the Bi-Xenon high beam pattern and the foglamps, I really do get an unbelievable amount of light projected forwards and upwards.
1 - 12 of 12 Posts
