Hi Everyone, I searched the forum, there is quite a bit of useful info on the topic but I need some experience based advise here.
1991 350SD
I had my mechanic refill the AC last summer with R12 and it lasted most of the summer. This year car was in for service for a lot of things and I asked him to put dye in so we can eventually find the leak, he said dye tends to destroy the system and he also forgot to refill the refrigerant as well (also didn't charge me so fine).
I want to accomplish a few things, refill the refrigerant myself. Is there a kit someone could recommend that they used with good result. I'm not sure if I should just fill the system up or do the complete process, evacuating whats there and refilling it. So need best advise there.
Secondly I do want to find the leak. Has anyone had any success using sniffers. If not what was a good method that you used, if you used dye and your system remained in tact which one did you use?
Thanks in advance,
Mike
1991 350SD
Thanks in advance,
Mike
