Questions on setting SLS height for a wagon
I'm curious about setting the SLS on a 95 w124 wagon. I know about the 4mm pin, the 'normalised position of the arm and the valve, but are you supposed to put weight in the car when setting? Is there a drop point to which the car should pick back up? I read conflicting things it seems and I wanna be sure I do it once and that's it. I read descrepencies about putting a little weight in the back then setting the normal position
