Hi,
Thanks for the insightful publication about the illum doorsil install.
I am having trouble relaseing the latch to get the seat back come off. There is this spring piece, but I dont understand how it moves.
Could you elaborate on that piece?
Member
'00 ML320 Elegance
Yes, I received your e-mail..
Hi,
Did you remove both covers in the trunk bulkhead area? Once you do, you can use a slotted screwdriver to release the two latches and the seatback will be able to tilt forward a few inches.
cool!
i got the rear seats installed this morning... the fronts tomorrow...
some comments
1. Safer to pull out the fuse before you do it. Its in the trunk left hand side. See your driver manual for more info. The fuse is #3 and its 7.5 amps
2. The hot wire for me was red and green. The best way to figure what it is for you is to pop off the rear dome lamp and see what color wire is comming out from it.
3. The switch wire for me was brown/pink
