1 - 8 of 8 Posts
CLK 240 2005
Hi to everybody! I´m from Spain! I´ve got a question please. My intermittent always are on since today :crybaby2: I think that the intermittent relay is broken..... and where is the relay????? Please help me. Thank you to everybody!!!!! Greetings from Spain!!!!;)
2002 SLK 32 AMG 1997 SLK230 & 1978 280CE
Unfortunately there is no cheap $10 thermal flasher ......in usual MB fashion they use a $1000 module to do the flashing.........
Replacing the Combination Control Module (part # 170-820-09-26) is the usual fix.......
http://www.benzworld.org/forums/r170-slk-class/1269736-turn-signals-stay-dont-blink.html
If you are game to dismantle this module, then this is a link to a fix of a sticking relay found to be the problem in one case...........
http://www.benzworld.org/forums/r170-slk-class/1355156-slk-indicator-lights-staying-possible-fix.html
Good luck
David
CLK 240 2005
Thank you.... I call to the MB Service and i ask which is the relay??? They told me (with the chassis number of my car) , that the relay costs +-10$. And the question is.... where is the relay?, behind the fuse box? And... is easy to change it? Thank you... but i´m afraid:eek: 1000$:crybaby2::crybaby2::crybaby2:
1 - 8 of 8 Posts
