Must Read CCV OM642
This CCV system has been an expensive problem for all of the OM642 owners: Chrysler / Sprinter owners alike. It should be MB's responsibility to address this issue of design.
MB CCV solution seems well intentioned and sound on paper, but unfortunately this CCV system has not provided the longevity that we have expected from MB.
MB Design:
It is important to not have the CCV vapors freeze.
Ice crystals destroy turbo intake blades, and oil/water emulsification forms when CCV vapors come in contact with cooler temperatures.
Unfortunately, the colder it becomes the more contaminates the blow-by gases contain. Having an effective CCV solution that functions in colder weather is always desirable. MB has achieved this end with it's existing CCV system including it's short CCV outside tube to the turbo PN: 642-010-18-91
MB idea: heated/enclosed/service free/centrifugally controlled blow-by oil separation. BUT....
Problem:
The volume of the 0M642's blow-by gas exceeds it's design volume parameters as the engine ages. As blow-by volume increases with age so does crankcase pressure.
The aging 0M642 begins to create more blow-by volume as the piston rings and engine tolerances begin to increase, (soon after 80k km).
The blow-by gas volume over powers the internal centrifugal oil separator's capacity limit.
The inability of the OM642 CCV system to separate increased oil mist volume from the CCV system as the engine ages ...ever slow-slightly increases blow-by pressures, which manifest themselves at the weakest point... the oil cooler seals. That is why MB issued the new THICKER vitron oil seals.
It's well known: referenced:
Mercedes-Benz OM642 - Wikipedia, the free encyclopedia
"... In addition to the oil cooler seals; this engine can also have an issue with the design of the positive crankcase ventilation system." THEY are related.
Real Life Practicality:
• Why are there not 2 centrifugal separators?
One for each bank of cylinder heads, on each intake camshaft.
Rather than just one?
They would both be able to connect to the turbo inlet at the same junction.
Owner's Facts:
• Catch cans cause oil seals to fail pre-maturely.
(increased CV pressure through restricting blow-by gas volume.)
BAD
• External oil water coalescing filters freeze.
Causing pre-mature engine damage through cold weather and lack of service.
(They are expensive and add to the already high serviceability issues)
Raco/Pro-Vent/Fleet-Guard...
BAD
• Atmospheric Venting OCV: Also reduces engine life by introducing un-filtered air and contaminates directly into the crankcase, causing real internal sludge.
(Not to mention the ecological issues)
BAD
It's Diesel not GAS...
• The "Italian Tune-Up" is not advisable on diesel engines, especially an OM642 with over 80k km, as you raise engine RPM you also increase the blow-by volume and pressure and the amount of contaminates in that blow-by... that will pass oil mist into the entire intake system... (not cleaning it, making a oilly volcanic mess)
1500 rpm produces 1g/hr of blow-by (with clean air filter)
2500 rpm produces 67g/hr of blow-by (with clean air filter)
2500 rpm produces 232g/hr of blow-by (with dirty air filter)
• Maintain you air filters in PRISTINE condition ALWAYS!!
This really is your only defense against CCV pressurization.
GOOD
• Double the frequency oil changes after 100k km and replace oil filters individually after severe operations.
GOOD
Myths:
• Turbos do not need lubrication via the CCV, if you see oil on your turbo intake seal... that's not a good sign.
• Oil/water mixing with the EGR system is a CLOGGING chemistry to any intake system, so keeping it out/low means a cleaner intake.
• Why no centrifugal oil cleaners on this motor, or after-market heated - electric drive centrifugal CCV oil/separator similar to the VOLVO D11 - D13 system.
Honorable Mention:
We all need to thank the countless hours of our friends in the JEEP and SPRINTER world for all their dedication and persistence to their trust in their OM642s.
