C220
I have a 94 C220 and am wondering how much coolant it takes if I want to do a flush. Is it 8 L total (50/50 with distilled)? And is this amount in reference to filling half way up the expansion tank? I'd like to know the exact amount because I am going to back calculate the ratio of coolant to mix (a little over 50%) based on the engine block being filled with 100% distilled after I flush.
· IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
8l should be total system fill so 50/50 is 4L and 4L. also keep in mind that the system does not completely drain out some of it is stuck in the heater core
2000 C230 Kompressor Special Edition
t takes me a couple if days to get it filled properly. I've drained it twice.
On MB systems (and BMW) you fill the reservoir bottle near to the top, right up to where the black portion begins. I then check it once a day to see if it needs topping off.
2009 C200k Avantguard.
If you turn the ignition key without starting the car, then turn the heater and fan on to max you should-according to my mechanic- get most of the coolant in the heater core out.
I did this and found more coolant drained out, pretty close to 8 litres.
