2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
There are brake sensors for the front brakes, but not a similar sensor for the rear. Is there a sensor for the rear that warns you that the rear pads need replacement? Does it activate the dash lights as well?
Discussion Starter · #6 ·
Follow up. The ML has the same brake sensors in the rear as the front. My replacement pads came with sensors for the front, but not the rear (go figure).
The sensors are $17 from the dealer (per pair?). The sensor is just a 3 inch wire that sticks into the brake pad and has a waterproof connector on the other end... (value ~$1 at most with connector).
When you replace your pads, don't forget to pull the clip-on antisqueal shim from the old pad and clip it onto the new. You'll regret it loudly if you do!
