1995 E320 Sport
Hi Everyone,
I'm trying install subs in my 1995 E320. I have everything pretty much complete, except I cannot find how to get the amp power wire to the battery.
If anyone has helpful information I would greatly appreciate it.
Thanks in advance. :thumbsup:
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
Pull carpet from trunk and board gaurding tank, fish it through back seat, under carpet passeger side then through the firewall to the battery. Run a good wire to it as the systems wires wont support the amps. Also suggest changing the alternator to a higher amp unit. Lots of threads on that.
1995 E320 Sport
Thank you for your response, although my issue is that I cant find an opening in the firewall. Where would it be located and how do I access it?
'91 C124 300CE, '06 W164 ML500, '00 BMW MCOUPE, '65 COBRA REPL.
Remove the battery.
Remove the shield behind the battery that protects the
Ecu.
U should see a grommet somewhere there.
Get a rigid metal coat hanger and feed it through.
U should be able to c it in the pas. footwell.
U should remove before all this the carpet and the alarm module cover,
this way u have better access. Then just thread the thick amp wire under the carpet.
U can get the amps trigger signal from the antenna's blue wire in the trunk.
1995 E320 Sport
Remove the battery.
Ecu.
Awesome, thank you. You also answered another question i had, which was where to get the rem signal from.
