1 - 9 of 9 Posts
'10 Mbz S550, '03 Mbz C240, '03 Audi A4 2.0 Stroker, '08 Lexus SC430 PB Edition, '07 Prius
Good to be back here on Benzworld for a change.
We just picked up a 2010 W221 S550 with the face-lifted LED headlamps, DRLs and tails. So my question was:
Do the 2010 S550's come with the Adaptive Tail Lamp feature? In other words, do the brake lamps flash rapidly under heavy braking like on the pre-face-lift models?
I have looked on google and even searched here with no answer.
If someone could help me out, I'd appreciate it.
MY10 S600 & S65 only
Do you have any concrete info to back that up?
I know this sounds ridiculous, but I want to be sure.
It doesn't make sense that they would not put that system onto the S550 after it has had it for over 3 years as standard. If not I'm sure a simple coding would activate the system.
S600
A lil off topic,,, i have an 07 600 and i want to get the 2010 led's how hard is it to install them and does it require any wiring or other modification?
Info is much appreciated.
I apologize Sir Konigstiger, I was unaware that you are the Diagnosticator of this forum.
I have not been on Benzworld for awhile other than in the W164 and W164X forum. Just got the S-class so my bad.
1 - 9 of 9 Posts
